Auris hybrid 2014
Matt85uk
Hello everyone
Hopefully everyone is health and safe
Just curious if it possible to replace LED day running sidelight bulbs in Auris hybrid 2014? I looked at it but is seems that is sealed? And can’t replace the bulb, unless I am doing something wrong.
many thanks 👍🏻
If it's anything like my Mk4 it's a sealed unit with no separate bulb. Is something wrong with it? Under normal circumstances, LED lighting systems should last the life of the car!
As cyker has said they should last longer than when the vehicle was registered you have to replace the complete unit I would check the wiring plug first and any earth connection.
well, there is nothing wrong with the Sidelight. Both sidelight work perfect.
I was only curious if these bulbs are replaceable as I can’t figure it out. I have both headlight and fog lights 6k led installed so I thought that I may upgrade it to match everything in 6k including sidelight.
It seems that it can’t be changed so that’s fine
thank You for your help
