Are these Engine Oil OK?
roks
Hi All,
Car was due an oil change October, been a bit busy and maybe a little lazy.
Weathers not great but thinking I better do it now or it will be another 4 months before the weather improves. Been thinking are these oil ok? these are the cheapest ones I found.
https://www.ebay.co.uk/itm/112573418838
https://www.ebay.co.uk/itm/143767948481
Both 0w20, one is SN and other is SN Plus.
Thanks.
Kerax is an oil refinery based in Redditch - previously owned by Castrol and BP, now owned by Certas Energy. Certainly OK for your use.
Mannol Oil is German with their oils blended in Lithuania and Ukraine. Think they supply OE oil to the Toyota plant in St Petersburg. Again OK for your car
I personally will never buy and use mannol products again after really bad experience with their brake cleaner which contents acetone and can caused a lots of damage to many parts including metal ones for which actually should be used. Was kind to try their oils but after what happened, full stop for me. Not recommended. 👎
OK, thanks guys for your input, I will go with the cheapest, hope its dry this coming weekend.
Best regards
