Missing locking wheel nut
Ruth Black
I don't know if it applies with Toyota but if you look on eBay, there's firms that can work from a photo of your existing wheel nut pattern and supply a key. I did this twice with Vauxhall cars. Can't remember the exact firm but was fairly easy to find by searching eBay
Hiya- that’s amazing - thankyou very much. I’ll go have a look and can hopefully get one from there
many thanks
ruth
On 12/13/2021 at 9:38 PM, TonyHSD said:
if you on a hurry to get these nuts off the car without damage anything even them, you can do that with simple trick. Use standard 1/2 bit slightly smaller diameter than the nut itself, 16mm 17mm or 18mm for example, use a hammer to snap it on and use a breaker bat to undo. You can get those of all 4 wheels and replace with new set of nuts or standard ones.
Good luck
That’s seems similar to my solution to the problem Tony 👏
