Seats Needed UK only Mk1 Auris
ussy7861
Hi
Does anyone know if I can get a hold of the seats in the picture I've tried everywhere and no one seems to have them.
Depending how much you are willing to pay, might be cheaper getting someone to reupholster the ones you have.
Mine are broken so no point
I've found some for 200 just wanna know if anyone has some or knows anyone
16 minutes ago, ussy7861 said:
Full set
Lol that’s cheap, just grab them while you can. These are the best seats of all for the first gen auris and lasts ages. Material is great plus the leather on the faces is real, behind and on lower sides is leather like but matches well. 👍
I have an issue with the rear seats, the brackets are different but the person who I bought them off doesn't have the brackets.
Is there any way of getting the brackets.
Toyota doesn't have them too.
Probably because these are from a hybrid and the Battery is located behind them., can you just take brackets from the old seats and do some intervention to make it possible to fit onto the new seats? As last resort you may check if possible to swap the outer covers from new to old bases, not sure if that possible, just my thoughts. Good luck 👍
Auris mk1 pre face lift and face lift seats fit either model, just watch out for 3dr and 5 Dr.
3dr do fit a 5dr but with a small mod to outer lower fitting.
5dr fitted to a 3dr will be awkward as sit higher on rear seat base
And of course you need the front seat tilt fitted for a 3dr
