2005 RAV4 D4-D Cutting out
NeilJ
Hi, my 2005 RAV4 2.0 D4-D starts perfectly then after 20 seconds or so cuts out as if the key has been turned off. It will then start back up without hesitation. When trying to drive it, it sometimes cuts out, other times it will drive for a mile or so aslong as I keep the revs up. It’s showin fault code P0200 injection circuit open. Has anybody had this before and what rectified the fault please?
Thanks in advance
Thanks in advance
firstly inspect SCV mounted on the fuel pump body.
i ve had similar issue b4 and the problem has been connected with colenoid coil short cut.
i ve had to change this SCV and to checl all el contacts belong to fuel injection group.
cheers / Igor
