Hiace 2.5 D4D
riakan22
Hi guys spent alot on my hiace but no joy.anymore idea's what can it be  garage have replaced injector 2&4 new tank.van has the same issue as before not pulling uphills then the engine on rough idle  when it's comes to a stop no warning lights for codes.
 someone let me know if the injection value below are right on my van.
1/  124
2/ -140
3/ 94
4/ -140
The above figure are while vehicle is on move.
1/ 5.0
2/ -5.0
3/ 5.0
4/ -5.0
Above figure while it's stationary
Many thanks
This era of d4d are notorious for SCV issues what will causes rough idle and low power, i take you have also checked the turbo has no play in the shaft
have the injectors been coded correctly ?
What is the calculated load, at idle and up to temp ?
Thanks for the reply I will get to you regarding the load on idle
Calculate load 16% when it's warm.
Inject1 feed value 1.09
Inject 2 feed value-1.09
Inject 3 feed value 1.25
I ject 4 feed value-0.94
If that helps
Looks like it's in the ballpark -3 to 3, the load could be a fraction lower but that maybe due to the weather
