OBD2 Port Surf 1KZTE and Bluetooth ELM327 device
1KZTEdiesel
I have an under dash port...it is an OBD2 port.
ToyOBD says that if a Toyota port has SIL pin on the pin out ..then it is OBD2, see http://jfbreton.blogspot.com/2014/02/toyobd1-android-datalogger-what-engines.html
Googling tells me that SIL pin is pin 7
My 2001 has a pin 7...interesting.
Then I learn that not all OBD2 protocols are the same.... each requiring an initialisation sequence and set parameters. Here is an example of how someone got a JDM Corolla to work by going into the advanced settings of the Torque app to insert an initialisation string ATIB 96 \n ATIIA 13 \n ATSH8113F1 \n ATSP A4 \n ATSW00 https://au.toyotaownersclub.com/forums/topic/29475-obdii-reader-for-zze-corollas-now-working/page/3/#comments
Commonly a bluetooth app will cycle through the OBD2 App (Torque is one that does this)....until it completes the handshake and then it connects
Anyone here know either:
a bluetooth app that includes preconfiguration for JDM 2001 !KZTE
OR
what the init string looks like
