Oxygen Sensor Bank 1 Sensor 1 Heater Malfunction
nkundalia
My brother has a 2005 1.3 VVT-i T Spirit 5d Auto.
Since UK has moved to E10 fuel his Engine light keeps coming on and the ODB ready is telling us the O2 sensor is gone, but we got it replaced by our local garage with a 3rd party replacement part and it's still popping up with the same error
Our mechanic suggested getting an original Toyota replacement part for it, but i wanted to see if any one else has seen this issue or it could be something to do with the new E10 fuel type.
Apologies is this is already raised, i did try searching for it but didn't seen anything here, hence creating the new post
Thanks in advance for any replies!
N
Quote
Car Scanner ELM OBD2
DTC report
Selected brand: Toyota============1==============
P0135
Raw code: 0135
ECU: 10
Status: Confirmed
OBDII: Heated oxygen sensor (HO2S) 1, bank 1, heater control - circuit malfunction
Toyota: Oxygen Sensor Bank 1 Sensor 1 Heater Malfunction
Try premium petrol with 5% ethanol and see what happens.
Hi Michael,
We've already been trying this, still getting the same issue
Thanks for the suggestion anyway
N
Check bank1 sensor 2 with a meter
What are the voltages from the sensors with the engine up to temp
The daughters car was doing this, they changed both lamba sensors being the cheapest option but it turned out the be the more expensive option the cat was at fault.
1 minute ago, flash22 said:
Was the correct sensor fitted ? Denso DOX-0257 is the correct oem sensor
I'm not sure,  but other mechanic suggest getting an original part, so I called Toyota to get the exact part/number but they would only give me a quote of £174.  I'm guessing what you've mentioned here is the original part I need to try!
I see that online for more than half the price of Toyota
Thanks will also try this!
