Lower joint steering ballpoint.
Peter Ling
Hi everyone,
T25 D4D 2.2 T spirit.
I am going to change first the front nearside suspension arm due to corrosion. It was an advisory on the M.O.T together with the 2 rear suspension arms. I'm going to change the steering ballpoint too. Are there different sizes of ballpoint for this model?
Somehow, I have a feeling that there might be.
I would appreciate any help with this.
peter
Ball Joint ? the lower balljoint usually comes with the arms (front), you will need to get the correct item for your car
have a look on the BluePrint and Moog websites
Thank you Bob. Will do as you suggest.😃
  • 9 months later...
