Hello
Amine
Hi guys I have yaris 2007 1.3 I went to toyota dealer to diagnosed my car and finally they found problem with timing chain and they ask for repair 1200 pounds and this is really insane I went to some garages they ask 800 pounds so I did it by myself and everything's goes well but when move the crankshaft the timing chain still bit loose is any help guys that's will be appreciated
Regards
Moved to the Yaris club.
What is loose, the chain tension or play in the sprockets?
Did you replace the sprockets? All parts of a chain drive are subject to wear, therefore all should be replaced together IMO.
