Park assistant not switching
When I press twice, Parking assistant does not switch to perpendicular. It give me only one option which is parallel parking. How can I fix the problem?
Hi and Welcome. I had a similar issue when I first tried the parking system.
Have you centred your C-HR in the centre of the bay in which you want to park before activating the switch?
The manual reads:
Stop so that the center of the target parking spot appears nearly perpendicular to vehicle. Then, press the parking switch twice and check that the display on the multi-information display switches to “Back-in Parking”.
Hi
Thank you for replying back to me. I will try that.
I am pure sure, it was giving the second option while driving in the street at the beginning.
i will tr
have a nice day
