a/c iq cab filter
Mercianman
 Image is the same as my 2011 IQ 1.0 litre petrol, on checking the internal cab air/ vent filter not one fitted
Does it have AC, Looks like a Base IQ, iirc it's in the heater/fan housing right at the back close to the firewall (passenger footwell) behind a long thin cover
Quote
Thanks Bob ,yes it has air con, the fan /heater as shown I unclipped the front, it with a  wide blade screwdriver nothing inside, is this where you say you locate it ? or engine side of cab
Thanks for your prompt reply Mr Frosty Balls,
My filter vent unit I think is not the square one it is like the image one i have removed the one in my car but there is no filter
They are just the vents that blow the air into the cabin the filter is where i described above
Pictures from a LHD (drivers side) it is in the same location on RHD (passenger side)
thanks flash,
have found it but how the heck do you get to it, cant even see it to unclip it
thank you very much for your help
It seemed a lot closer to all the bulk head than they describe cant see how to get the locating/securing plastic bar back at moment will try tomorrow
