I’m getting a bit of vibration/knocking feeling through my steering wheel but only really when on the throttle and even more so on lift. Not sure what all the best points to start checking are. I mean the car is 20 years old. I kinda hope it’s not driveshafts as you cannot source new ones you can’t even source the inner cv joints now they’re redundant now.
But coasting it seems to go away and the vibration/knocking feeling on steering seems to be worse the harder you accelerate.
other than this I also get a clunk sound if you lift clutch up a bit too quick if you’re trying to pull off quick too. This started about w month after I got a new clutch and has been like it for a few months not sure if somethings slightly come loose after settling.
Any ideas would be appreciated
video shows the knock lifting clutch up best way to try replicate it on the spot as wouldn’t be able to hear it over the engine and exhuast.
