Hey. Does anyone know the size of the ignition coil retaining bolts on 2008 Aygo? Mines are rusted and want to replace before get weaker
not off hand but I know a 10mm socket fits so assume they are 8mm. use WD40 ? when trying to remove and work bolt back and forth gently for a short tiem  before trying to unscrew fully to allow fluid to penetrate along threads .its corrosion that can have us breaking a bolt and we don't want that and we do not want issues it creates!  when fitting new? bolts apply a smear of copper or nickel grease to threads . thsi goes a very long way to reducing corrosion mainly by filling in any air gaps in threads and acting as a corrosion inhibitor etc
