Yaris t sport which is best spring to buy? Split between pi 40mm or tein s tech 35/38 please help
xav
Hi please could you guys let me know from experience which of these springs are best for best handling improvements and looks, I know they are very similar drop
Can't find pi spring ratings and I don't know if they last like the teins will over time?
Any advice very appreciated
Depending on your location and/or where the car was imported from, the SR may have come standard with 25mm springs - aftermaket springs are compared to a standard car so if the car is 25mm lower you will only get another 15 mm drop -the car will also settle 5-10mm over time
Eibach or H&R springs are what i would use, and replace the bushes with Poly like the Superpro's
https://www.superproeurope.com/products.cfm?vehicleid=14086
https://www.fensport.co.uk/collections/toyota-yaris-1-3sr-nsp90-11-08-12-11/category_chassis-tuning
Go for the Teins, they make the car sit nice and level. Teins have been proven many years ago no too stiff and excellent build quality
Thanks for the reply, I was leaning towards the tein as they cost less and levels the car up like you say, also lasting quality
Think you just helped make my mind up
Cheers
