2 hours ago, JoaoM said:
Would like to know who is the OEM
Factory fit blades are usually Denso. Toyota Optifit (Toyota's cheaper range} are made by Trico.
  • Like 3
Posted (edited)
On 6/17/2023 at 10:49 AM, PetieT said:
Since you have a 2020 model, I wouldn't change it overall. From 2019 they have pretty good brushes
They are good but wore down, so I must replace them by the end of summer. Have found Denso's hybrid model at Autodoc much cheaper than at Toyota's shop.
DU-070 and DU-035
Add an L or R to these references if you have a LHD or RHD car, respectively.
For the rear one need DRD-014 but it's not available at Autodoc at the moment.
Edited by JoaoM
References
DU-070 and DU-035
You can source these from https://www.carparts4less.co.uk or https://www.opieoils.co.uk I belong they do international delivery too. 👍
