Gas pedal
Mariosskoutaris
I  noticed that my gas pedal has something like a deadspot or unresponsiveness for the first inch or so I don't know if it was like that from the beginning or if it developed over time. Note that when you pass that inch it doesn't like jump on rpms instead its smooth as it should.
Any ideas?
Thanks.
If you press harshly, then it does something, if you slowly press it, nothing happens?
Mine is the same, the magic of ECU controlled drive by wire.
Maybe it's to isolate jerking the car when starting, never really bothered with it, never had any issue, i only noticed it when idling, i tried to rev and was lazy unless you pressed it further.
8 hours ago, Mariosskoutaris said:
Παρατήρησα ότι το πεντάλ του γκαζιού μου έχει κάτι σαν νεκρό σημείο ή αδυναμία απόκρισης για την πρώτη ίντσα ή έτσι δεν ξέρω αν ήταν έτσι από την αρχή ή αν αναπτύχθηκε με τον καιρό. Σημειώστε ότι όταν περνάτε αυτήν την ίντσα δεν του αρέσει το άλμα στις στροφές, αλλά είναι ομαλό όπως θα έπρεπε.
Καμιά ιδέα?
Ευχαριστώ.
Good morning First clean the egr valve
Egr is clean and i also have a DPF delete.
You had a remap or just a dpf coded out?
It's just a worn pedal, the car has relearnt the pedal position over time
Any ideas?
Thanks.
just the dpf
