Yaris mk3 2018 Bluetooth not working
Seddik
I purchased toyota touch and go 86140-0D320 for my yaris III
bluetooth was not working
I try to ground pin 6 with wire but not working
I purchased toyota original mic an i install it but nothing new
bluetooth still not clickable in the setting menu
Any help please ?
Did you ground the correct pin 6, depending on the diagram the connector view may be different
later cars have pinout variation as well
Yeh i try to ground the right pin but nothing works , this method was worked in other reference 86140-0d321
The only way to turn on bluetooth is to install navigation module on my 86140-0d310
So can you find another pin to detect that the navigation module is installed ? (like pin 6 to detect the mic)
the units are identical hardware wise if you have the nav module the mic is routed through the DA to the Nav, the Nav takes control of the bluetooth and USB
make sure the Nav is unpluged and the cables removed inc the bluetooth aerial
make sure the Nav is unpluged and the cables removed inc the Bluetooth aerial
Okey tomorrow i will test it
Thank you
