PHEV Tools….
Flatcoat
With a Dynamic Premium - what should I have? I appreciate there is no spare wheel however No sign of anything, no jack, no wheelbrace…. no ???? Or does the specifying a sunroof render the car puncture proof…..
You should have a towing eye and nothing else (I believe) ...
You don't have a spare wheel, so you don't need wheel changing tools - they just add unnecessary weight. If you have a problem, call the AA and let them sort it - other roadside recovery services are available.
Or, yes, I was rather surprised too! 😉
You think Toyota would supply a jack so you can rotate your tyres as recommended in the manual.
Not everyone wants to rotate wheels themselves, so they wouldn’t need the extra cost nor weight. Buy a scissor jack yourself. Nor do I want to be changing wheels (puncture), that’s why I join Start Rescue.
just stating an alternative opinion, there is always an alternative thought.
Think through the scissor jack routine for rotating wheels.
1.  Slacken nuts - jack car - remove wheel
2. Slacken nuts -.........
Unless you have a spare wheel or axle stands you will be operating that jack like..... on boat race night 😁
If you do want to DIY you need a minimum of two jacks but better a trolley jack and axle stands.
Just go to a tyre shop, few quid, job done.  I paid about £50 for tyre swap summer to winter, just doing wheels should be coffee money.
Roy. I should have remembered you don’t have a spare wheel to use🤯.
I’ve got a spare from a previous RAV. Not having a spare or space saver is a no no for me. Could be waiting hours for the recovery services assuming you’ve have a mobile signal.
  • Haha 1
robo, I have a spare and a trolley jack but I shall ask the garage to do the rotation next month.  Even using the spare and jack would be a pain.  Sadly I got rid of my axle stands on house move.
Agree, no spare could be a 100% ation factor. Even a space saver is less than ideal.  As related earlier, a puncture at Southampton necessitated a 100 mile journey through France until I found a garage with a suitable replacement and the willingness to change it. It also required me to put the u/s tyre in the back seat with the children as it would not fit in the SS stowage.  SAAB helpfully provided a bag.
My Corolla has a full size tyre well.  Obvious solution is to buy a steel wheel and get a garage to swap that spare rubber when tyres are changed.
Thanks for responses. We tow so a space saver is of limited benefit, not suitable for use if towing. I will ask the dealer about the towing eye and source a wherlbrace and jack. I may still have an old small bottle jack that might be safer than using a scissor jack (never really trust them) and less bulk and weight than carrying a trolley jack.
Towing eye was in a plastic bag with mine. It was either in the glove box or with the charging leads. It wasn't in it's slot so worth having a look in other hiding places!
Also no tools provided. I asked the question previously when I got mine as other cars with gunk and pump still had them (not that I used them!)
Flatcoat, I would disagree about the space saver and towing.
First you are as likely to experience a flat when not towing as otherwise. Second, if you have a flat while towing that a inflator cannot fix, fit the space saver and tow to a safe place.  Then at least you can enjoy a cuppa in safety. You can then unhitch and drive to get it fixed.
