Hi all
I have a Toyota 2005 Semi Auto MMT old shape . 51k on the car HPI clear so never in any accident.
I bought the car and the clutch was gone. I fixed the clutch and then drove 10k miles
Then car broke down. The car is trying to start but engine will not turn on on its on like a normal car would
Recent fixes/issues:
1. Crankshaft sensor: came up and now it doesn't
2. Cam shaft sensor: changed but error keeps coming up as cam shaft sensor circuit bank 1 (used two cam shaft sensors, still nothing)
3. Fuel pump is fine
4. no spark from spark plugs
At a point now where I really don't know what to do. Please can someone help?
Change the crank sensor a crank code will only show if the engine is running at the time, if you cleared the codes it may not come back
I tried that several times 😞
Where did you get the camshaft sensor, are you sure it's genuine and good quality as there a lot of 'fake' car parts around (in the US they Call them CRAP - Chinese Replacement Auto Parts)?
Have you checked the wiring to the camshaft sensor?
I would be checking fuses - IG1 and IG2 on the side of the gauges
does it have a good Battery, what's the voltage when cranking ? Has the car been jump started ?
The sensor is after market as genuine one is quite expensive. Surely that shouldn't make a difference? I just visually inspected the wires and no cuts. I was thinking of getting a multi meter and checking it that way. How exactly do you mean? Thanks
does it have a good battery, what's the voltage when cranking ? Has the car been jump started ?
I checked all fuses inside and near engine and nothing was wrong.
Battery is dead as hasn't been driven in close to 4 months now. I just keep jump-starting if but the alternator has crack in it which I don't think could be an issue
Voltage I need to check with multimeter
What do you think?
Well, you can't diagnose an issue without a decent Battery - Aygo's don't like to be jump started they can blow the fusible link, if the Battery is dead jump starting will do nothing the ecu and other systems will not power up correctly
If the Alternator failed,  the Battery willl drop low the ecu will go mad and throw all sorts of codes
Back to basics - Battery and alternator
Topic title changed to reflect topic subject.
On 1/16/2022 at 12:23 PM, flash22 said:
Well, you can't diagnose an issue without a decent battery - Aygo's don't like to be jump started they can blow the fusible link, if the battery is dead jump starting will do nothing the ecu and other systems will not power up correctly
If the Alternator failed,  the battery willl drop low the ecu will go mad and throw all sorts of codes
Ah I see what you mean. Do you think to change the Battery and Alternator?
Kam possibly but have you tried charging the Battery?  It is probably knackered (u/s) for long term use but might work while you keep fault finding.
As for the alternator, how do you know it's knackered?  Maybe it is which accounts for the Battery, or the Battery is knackered so there is nothing for the alternator to do.
  • 2 years later...
Hello guys
My Toyota aygo 2014 mk2
Met with an accident and all airbags were deployed and i already replaced all the airbags and srs airbag module but it won't start. It cranks but won't start
 Ads i notice when the ignition on but no sound of. Fuel pump and the obd is also not detecting
So do anyone have the solution
do you have power to dlc3 (obd2 port)
is the Battery connected correctly
Yes when i conmet obd2 it lights up but after few seconds it says that it failed to connect
as i have changed the Battery also but still not starting up
as i check all the fuse and relay its all working but when i give ignition the fuel pump dont do noice
does the engine crank ? has the car been jump started?
Finally it started.. It was the fuse that blown off coz of o2 sensor got short. As i plug the fuse it just got blow away so i  unplug the o2 sensor and then tried the fuel pump fuse and it got started
Thank you
Which fuse had blown I'm curious cos I've peugeot 107 auto that cranks but doesn't fire I've no error codes.
 When you give ignition did you hear the sound of fuel pump?
If no sound from fuel pump then check the fuse that has on drivers. Side under the dashboard. No 20 the green one
Yeah I can here the fuel pump when I turn the ignition on and here when I crank it if I crank it a few times I can smell petrol I've no error codes so it's like looking for a needle in a hay stack
