Avensis T25 2.2 D-CAT wagon 2006 MAF sensor
samuelsama
Helo!
I have bought an avensis 2.2 D-CAT 2006 4 months ago.
The problem is that in idle the rpm is at 1000 when the weather is cold and humidity is high. Slow response when accelerating and unstable rpm.
When disconnecting the conditioner controller the rpm are always ok.
I scanned  with OBD2 and there are two codes shown: P0102 and P0113.
I searched and it is about MAF sensor. But when tested with OBD2 it shows the values changing.
When I looked at MAF sensor I found that it is an aftermarket one, it was not the OEM. It has some numbers on it that on Google doesn't show anything.
Anyway I disconnected it to see if it was dirty but looked OK to me.
I want to try to buy another but I don't know the OEM one that is compatible wit my car.
Can anyone tell me the code of the MAF sensor please? (motor 2AD-FHV, 130kw, 177hp)
I have searched this ones but I don't know if they are compatible: 22204-22010 and 22204-0N010.
Thanks in advance!
