Cruz Airo FIX roof bars
ToyotasGoForever
Hello
I'm trying to buy some Cruz Airo FIX  roof bars but am on a budget.
I've found some on eBay but they're 118s (10cm longer than the 108cm ones I need).
Do you know if these can still be fitted to an Auris Touring Sports 2015 model? Can't find out anywhere but general rule for Thule ones is they will likely be ok if a bit longer, just not shorter, so wondered if it's the same for Cruz ones.
Thanks in advance for any advice.
Thanks. Fair point, just wanted to ask here because Cruz probably won't advise buying used etc. so I wanted to see if anyone had done it 👍
Just ask whether the longer bars will fit - no need to mention whether they are new or used.
Thanks FrostyBalls, much appreciated.
