Aygo [2005-2014] Radio AUX to Bluetooth modification
Hello guys,
I like to keep my cars as stock and clean as possible, that is why I thought about using this type of module to turn aux port in stock radio into bluetooth port.
Unfortunately AUX is built in the radio itself so there is no 20pin connector at the back. Is it somehow possible to connect this type of module to this radio?
I know the easiest way would be to buy aux bluetooth adapter, but I don't like the idea of charging the adapter every now and then.
Thanks!
That adapter relys on the radio having a connection on the back for an external CD changer, which the OEM radios don't have.
I think the best way to keep an OEM look is to investigate the radio fitted to the later Mk1's which AFAIK had bluetooth and USB support?
What radio do you have ? bluetooth for music, phone or both ?
There are 4 types of connectors for the mk1 aygo
ps. CD changer is 16 pin
