Hi all I was going through the corolla settings & found this "MID OFF"  in the settings menu & got me curious.
Does anyone know what it is?
you can set the Mid so it comes on as you open the door to display the mileage or i may be something todo with the HUD, the owner's manual will tell you
If I remember right, it turns off the center square part of the display ( the part where actually the setting menu is)
So you see only speed a revs and if you press the "ok" button it will appear again. But I can be wrong, tried it long time ago.
Turns the Multi Information Display off when the analogue/digital speedometer is displayed. Page 104 of the latest owners manual.
Thanks everyone I downloaded the manual & had a read 🙈
