Auris hybrid
Tee 71
Any info would be appreciated,I have auris hybrid 2016.the last few days it has developed hesitation and a rattle when idle at 2 bars on hybrid Battery charge....the things I have done so far are as follows
Cleaned the egr pipe
Cleaned the throttle body
Changed the spark plugs
And service the car still no joy
Any information would be appreciated thank you
Also no error codes on a check either..hesitates more when i drive sometimes it goes then comes back thanks
Hi, it’s the egr valve, egr cooler and intake manifold the small holes where the air goes from egr pipe into the combustion chambers, these needs properly cleaned. Here on the picture shown with red circles. New gasket for the manifold should be used afterwards, and a good idea to replace or at least check the pcv valve located behind the manifold. Gasket cost around £20 and pcv around £30. Also I can recommend to you to use E5 99 petrol instead of E10 95, it helps against these nasty knocks, and as preventative maintenance a bottle of injector cleaner or catalytic converter and lambda sensor cleaner made by wynns, no others . Follow strictly the instructions.
Good luck 👍
Also this video will help you too. That guy has more videos about these cars very helpful.  You can search for manifold cleaning etc. Cleaning only the pipe will not do much, also the egr valve needs to be dismantled from the cooler and cleaned nicely.
