Disconnect battery
Hi everyone,
I would like to disconnect the Battery of my Aygo 1.0 X-Press (bought in 2020) because for 3 weeks I will not use the car. Do you know if it is needed to have the so called 'radio code' in order to be able to use the car when I will recconect the Battery again?
Thanks in advance.
No code..
Most cars of that age will sit happily for 3 weeks without the batteries draining.
I left my Mk1 for 6 weeks whilst on holiday in the US, it started first time with no problems.
Agree with the above.My wifes Aygo wasn,t used for 2 months recently.It started straight up a few days ago.I wouldn,t bother disconnecting the Battery.
If you been spooked by the batteries going flat on Toyota hybrids, I think you can relax, it is hybrid specific. As long as you haven’t already got a dodgy Battery, or an alternator not charging proper, should be ok.
Aygos are not hybrids, so that's not an issue at all
Hmm, so could we fix it by sticking an Aygo Battery in our Hybrids?? :laugh:
  • Haha 1
3 hours ago, Cyker said:
Hmm, so could we fix it by sticking an Aygo battery in our Hybrids?? :laugh:
If it will fit in alongside the usual Battery, sure, why not? A pair of parallel links.....instant Ah upgrade! 😁
8 hours ago, Red_Corolla said:
If it will fit in alongside the usual battery, sure, why not? A pair of parallel links.....instant Ah upgrade! 😁
... until one Battery starts to fail when the other Battery will try to keep it charged and will kill itself as well.
Connecting two batteries permanently in parallel isn't a great idea - where two batteries are fitted (e.g. in a campervan) they are fitted using a split charger system to prevent one Battery killing the other.
6 minutes ago, PetrolDave said:
... until one battery starts to fail when the other battery will try to keep it charged and will kill itself as well.
Connecting two batteries permanently in parallel isn't a great idea - where two batteries are fitted (e.g. in a campervan) they are fitted using a split charger system to prevent one battery killing the other.
It was a tongue-in-cheek remark, Dave 🙂. I wouldn't dare do it on a Hybrid for fear of overburdening the charging system.
I have seen it done on breakdown service vans years ago, because they were forever being used to give jump starts. I guess they rely on the portable units these days. I would imagine they used to upgrade the alternators, too, as that would be the main area of concern.
The welder / fabricator we use has a fancy split charge system on his Transit - the auxiliary Battery is used to run all the led work & orange warning lights fitted to the van.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
