Yaris verso drive shaft clicking
amazighman
Hi.
Recently our yaris verso has developed a clicking noise when you steer sharply , I guess its the drive shaft going bad.
Wonder if I can get away with replacing just the hub end CV joint rather than the whole thing , Is it usually the CV joint near the wheel that fails?
Thanks in advance
When's your MOT due? They'll only pick it up if it's 'excessively worn'. Yes, it's probably the outer CV joint. Find a quiet car park and use full lock, forwards and backwards to see how bad it is.
I can hear it from inside the the car.
I am going to order the parts , However I have seen there is a little circlip on the shaft , does that have to be removed for the CV joint to be knocked out?
When Installing new cv joint , Do you just hammer it home with a rubber mallet  and it slides over that circlip thingy?
Just now, bathtub tom said:
I'd suggest you look at youtube videos.
Looked at few that i could find , still not sure about that circlip
