Left Indicator and Brake Light bulb change
Mman1
Hi ,
I have just got a Auris 2017 TSS hybrid estate and noticed the left indicator flashing constantly-The bulbs are out ,can anyone share any tutorial how to change this
Many thanks
"flashing constantly" - do you mean quickly?
Front or rear? "bulbs are out", how many? It should explain in the owner's manual. I would assume there is some sort of access panel to access if at the rear or from the back of the headlight assembly at the front.
You Tube video will show you how. Ask on YT and you get shown as well as told.
