Did anybody ever hear about a change from cable driven clutch to a hydraulic one ?
Can it be done ? Is there a kit to do so ? Any idea of the cost ?
I think it would make driving the car more nice and comfortable.
By the way , just found this terrific clear movie on how to adjust clutch.
No idea if the cable is still as reachable on the 2021 Aygo but I am surely going to find out.
Nope, it was never designed to use a hydraulic clutch, the clutch pedals are completely different, the firewall has mounts for the slave, 95% of modern cars use a concentric slave, the gearbox isn't setup for it
The clutch cable in the mk2 Aygo is self adjusting
Ah ... Didn't know there was a difference between MK1 and MK2 for that.
Good to know then.
iirc it was around 2008/9 it changed when the 170mm clutch got upgraded to 180mm this included a new clutch fork and cable
I still hate to drive it a bit when the engine is cold. After a while it gets better though 🙂
Will have to get used to it one day.
With a cable system, you're disengaging the clutch by converting a pushing motion into pulling and then back to pushing. A modern hydraulic solution does away with all that and the pedal pushes against the clutch directly (via the hydraulics, of course). Because of this, hydraulic tends to be a little lighter and smoother, but I wouldn't say there's any advantage in terms of finesse. It's a matter of opinion and, of course depends on the particular vehicle and design. Not all hydraulic systems are pleasant to use, they too can be stiff and/or heavy, especially as wear & tear begins to take it's toll.
With self adjusting clutches, I know the type in hydraulic systems.
But with cables...
I saw the parts on photo .... Ok. It is a different part.
Can't find any explanation on the self regulating capacity of the current clutch model though.
Are you sure ?
Dne 28. 1. 2022 v 19:41, flash22 řekl:
Lanko spojky v mk2 Aygo se samonastavuje
Jak jsi zjistil jak? Systém ovládání a nastavení spojky je u všech typů Aygo stále stejný.
Dusan says the system is still the same, unchanged.
That's what I thought too and what was said here before.
The cable itself, as a part, is not self regulating if I see it.
Maybe flash22, who seems to know this car well though, made a mistake ?
If it's manually adjusted, the gearbox end of the cable will attach using a long threaded rod. This is where the adjustment is performed.
