Waterpump
Ade M
Hi all,
Does my waterpump run on the timing belt on 2.0 petrol 2002 a ensis please
Thank you
20 hours ago, Ade M said:
Hi all,
Thank you
Your engine 1AZ-FSE is timing chain, so no timing belt. The water pump is driven of the auxiliary belt. Look at the image for 1AZFSE for routing of the belt. Also check the tensioner and the auxiliary belt. I would replace the belt if not changed in recent years! The Haynes manual covers the procedure, but without the images.  Links added below.
http://www.japan-parts.eu/EU/3/161544C.png
http://www.japan-parts.eu/EU/3/160541C.png
http://www.japan-parts.eu/toyota/eu/2002/avensis/azt220r-almehw/3_273540_074_/tool-engine-fuel/1601_water-pump
http://www.japan-parts.eu/toyota/eu/2002/avensis/azt220r-almehw/3_273540_074_/tool-engine-fuel/1605_v-belt
