Option for front disc brake (Yaris 1.0 year of 2001)
vasyaris
hello,
iam intesrested to replace the front disc brakes on my Yaris 1.0 50kw.
what is the best option ?
OEM
aftermarket
the reason to asked is to avoid sound when i press the brakes.
i have found this :
https://kamoka.pl/en/products/8_brake_system/44_brake_discs.html
https://www.autodoc.co.uk/bosch/7884009
thanks in advance.
what is you are suggestion brand? the link are followed is empty
You have to put you reg number in or, your car details to find the part for your car.
I like to use Juratek parts.
What sound are you hearing when you press the brakes?
8 minutes ago, vasyaris said:
if the brake disc and pads are not OEM i hear an anoying sound
Is that a question?
5 minutes ago, Stivino said:
Is that a question?
no, my problem . that why i need to find qulaify parts.
I've given you two links to good websites.  All you need to do is enter you details.
All the parts from those websites are good quality parts.
Whats the mileage on your car and when were the pads replaced last? Is there a lip on the discs? Perhaps you could strip the brakes down, clean them and, regrease and see how you get on.
That said, it could be that your wear indicators(metal clips) on the brake pads are rubbing on the disc telling you that they need to be replaced. If you can post some pictures of the current condition that will certainly help
If you're worried about brake squeal, good quality pads and hardware (anti squeal shims etc) will be more important than the brand of disc. For similar quality to OE, I like Mintex or Brembo, but there are other good brands.
thanks for the reply!!. one excellent option is the OEM. other good option as you maintioned is the Brembo.  but i cannot find for my size. my car is Yaris 1.0 vvti yera of 2001. as i search the correct disc size is 235mm
You don't need to worry about putting sizes in.
Just put your reg No in and let the site find the right parts for your car.
Yes.  That looks like the Juratek site, they are the manufacturer and don't actually sell the parts but you can identify the parts and then look to see who will sell them to you at the best price.
No probs, it seems there might be more than one type of disc and pad for your car depending on the country of manufacture.
Your chassis (VIN) number will help you need to know.
Let us know how you get on.
