Wiper Blade Sizes
venomx
Currently have 14" on passenger side, and 24" on drivers side.
I'm looking to replace the passenger side one as it's cheap and hasn't last as well as the Bosch on the driver side.
Doing some research lots of people say 26" on the drivers which cannot be right as the gap between the two blades is too small to allow for an extra 2".
MK2 Yaris. Which size blades do you guys use ?
26" blades would be an inch longer at each end, so if the gap between your existing blades is more than an inch the longer blade would fit.
Nope its about half an inch at the most
Assuming they don't clash, why don't you just measure the blades you have and buy the same length...?
That's what I usually do - No chance to get caught out by inaccurate documentation then!
Just buy replacement sizes the same as factory fitted, no problem, no hassle, easy life.
"Fits: TOYOTA AURIS UK MADE Hatchback 2006 2007 2008 2009 2010 2011 2012
TOYOTA AURIS Hatchback 2006 2007 2008 2009 2010 2011 2012"
Are those in the link the same fitment as a 2008 Yaris?
Hi, @venomx I have been back to the dealer and git the following info for the Toyota Yaris Icon, 21 plate that I have. Front, driver side 26 inch, 660.4mm, passenger side 16 inch, 406.4mm, rear 10 inch 254mm. I have also come across these on Ebay https://www.ebay.co.uk/itm/133521725100?_trkparms=ispr%3D1&hash=item1f1683d6ac:g:G3EAAOSwTStfYze2&amdata=enc%3AAQAGAAACoPYe5NmHp%2B2JMhMi7yxGiTJkPrKr5t53CooMSQt2orsSHYXPhGXR5uguexJBeHwfgRkrdYH0YNfeIbM2AH%2FPtWEbxqsmxVyk2G0SZA2ymxoHDRlFrE0wlziS8Ty8vwCh9grn7yjcSn1M%2F7f8%2FncJTZWsq5IhyUC35dOc%2B8yC0jfVHSur2RrxuvQynuSGSVVSsvaeaDE3QsvGwyez2%2BSfPAHXL6rcuH9%2B6ZiIpBXLEJFPqR9k7DQoTb6kRaZrKBZ8Ho7H1G1oYdpCKJmq2e6kiuQEdmzncid2ptVVSXkZcD8xjaE9GGLSWqLrq3egRRrvt%2BeViixrYsUEU96Nhje2BTlzhDsyJdQqOS5suqleN06Bqu%2B9xKosng4BglP%2B0iFFbVleCVTLsaEZpoc7jrPoEJPIRgN2FBuKd2ba31BThaIhdUKd6NjacNbt7DAdxMsCvb%2Bu8ytQUNNRoT4fUh73NdqJqFcUTg7njieh%2Fd9XJeBH%2F8lkvBAfcFawFQBeO1qZAb8f4c%2B1RPPueuiYp6AQSfLcQLD7rH6TtO0zWqKwoppwlNlKpp7mR5TRFIfRGsV6YRhdNiAK1xNxwmrZV5%2BSqhnr2Y0HAGx68Pouf193RyumUbmPvv73G1qsMfryjd7FIfcctMXVzDYT5NYewNQ6GmVsCDhtbjCEM3rd7IcPIqJSVrcxVQ%2BLafhX6TC7xJtGeAVsh2j1u758XAmCCueaitDUy4BvBmHePhmWRh5eumG2kHSVrdfJ1tex07P8JnHRRdY6ZTmRj69ZfgM7HxR1K3TOF%2Fm0p3Qe9E6l5uojqg6UVKyOJ9C5Q462PwmGT%2BgjozVpTUlZ9tLpOdFkBurSTBTfM4POOFTdVzrjGyfFGa1rfBf%2Bx4A%2FLdfk38chbcnRvw%3D%3D|clp%3A2334524|tkp%3ABFBMmv6Vidtf they say that they are for a Nissan leaf, but are the correct sizes, look like the correct fitting and are only a tenner for the full set. Hope this helps. 😁
