Dash lights
Azza2022
Hi all,
I have a 2012 IQ3. When I turn the ignition off some of the lights and radio are staying on and draining the Battery. I have tried disconnecting the Battery and leaving and testing fuses etc but nothing is working.
wonder if anyone has had the same problem.
FIXED
Hi just in case anyone has the same issue with the above. We found that the ignition was switching back on after switch off by itself leaving dash lights on as though it was getting ready to start again. Keyless entry model. We replaced the start stop converter unit that is located under the Battery. Toyota have discontinued the old one for a new model. Replied and and all working correctly again.
  • Thanks 2
