Rear interior lights
BernieN
My 2012 Avensis Estate had a flat Battery this morning. This happened once before so I knew the problem. The rear interior courtesy lights - which you can't see for outside because of the tinted windows - were permanently on after I left the car.  According to the manual, they should turn off after twenty minutes noi matter what, but they don't. They were accidentally switched on when we put a lot of stuff in the back, which must have pushed on the switches.
According to the book a "Toyota dealer or other  professional" may be able to customise the settings, but my Toyota dealer wants £91 to look.  I wonder if the best thing might be to just take out the bulbs, but before I do, does anyone know how to see the settings for the lights?
thanks
Bernie
7 hours ago, BernieN said:
My 2012 Avensis Estate had a flat battery this morning. This happened once before so I knew the problem. The rear interior courtesy lights - which you can't see for outside because of the tinted windows - were permanently on after I left the car.  According to the manual, they should turn off after twenty minutes noi matter what, but they don't. They were accidentally switched on when we put a lot of stuff in the back, which must have pushed on the switches.
thanks
Bernie
im not sure if techstream can do away with this but taking out the bulb is a great idea see if Battery still runs flat
I think it must be a software problem.  I found the hidden menu - well, two hidden menus - but they didn't offer any lighting adjustments. I levered out the fitting and found that I could just unplug it. Hopefully that has solved the problem, though not in a satifactory way.
B
