3rd & 4th Gear noise
DaNSR86
Hi All
Got a 2010 D4D T27. Runs fine just coming up to 115000 miles.
Had the draft shaft replaced a couple of months ago after it snapped on me.
To be fair ever since the repair its been fine, just wanted to add a bit of history!
When I change a a low speed (somewhat low) to 3rd or 4th in my car I notice like a noise not a whine or a grinding noise but like a suspension noise. If I change gear at a faster RPM it doesn't make the noise. The best way to describe it is like a small wallow. The car goes into gear fine no other issues. When stationary selecting the gears is fine even engaging them works.
Has anyone else has a similar issue? I think its more to do with a suspension item purely because nothing mechanical is affected. I've had a gearbox and clutch go before doesn't feel anything remotely like that
Dan
