Solar charger for my Yaris hybrid 2021. Advice please.
BugsyB
Next step cover up solar panel or alternatively check at night to see if solar charge light is still on if it is then you need to fit a blocking diode.
I sugest using a schotty diode one rated at 4 to 6  amps
I fitted mine inside a plug but you can use a joint box.
Halfords 20 watt solar charger is for connecting directly to the Battery.
They offer a ODBII port adaptor but it for lower wattage panels and its at extra charge £.
