Leaking in boot
Maccie
Has anyone had problem with water getting in boot 59 plate avensis wondering if common problem thanks in advance
Saloon or Touring Sport?
Hi, Toyota all models has some issues with water entering the boot. Usually there are two common faults that let all that happen, water goes through the seals of the rear lights clusters or metal work , where two or more metal lists welds together, micro cracks. You can start from the lights , remove clean extremely well and replace seals, then clean all shut around the boot and water test.
Good luck 🤞
