21 hours ago, Red_Corolla said:
I had the Harmon Khardon option added to a 3 series and I think the sub for that went under the front seat. The sub does help a lot, probably delivers about 90% of the perceived improvement in sound quality, but the reality is you're paying a big wedge of money and still being supplied with cheap speakers.
Perhaps they still supply you with cheap Speakers, however those cheap Speakers are now setup correctly. A subwoofer plays low frequencies, door speaker plays midrange and tweeters play highs and everything wired through an OK amplifier. Even the most expensive Speakers wired directly to a head unit will not play very well because A) head unit does not produce enough power B) no way a speaker is able to play lows and midrange well simultaneously. That's why you setup a frequency cut off on the amp so that every component is responsible for their own range
