Toyota Avensis 2005 ABS control modul how install new?
KERLE
Toyota avensisi 2005 year, bought a used the same code abs modul, but cannot installed to the car.
Have some ideas for that, also went to see an electikal, he said he can t help.
Abs track off vsc is on the screen.
Years ago I have an ABS failure on my old Mk1 '98 plate Avensis. I did self diagnostics using the OBD paperclip trick, that pointed me to the ABS ECU. I replaced it with one from a scrapped car, that was a few years younger than mine. It was a bolt on and connection job, not touching the hydraulic side, so no bleeding necessary. The ABS worked immediately without needing to delete any codes, as none was stored. Hopefully this will give you some direction.
Here is my original post.
