Oil filter part number
DanTavensis
I've continued to use Castrol edge pro oil for the car and want to buy original oil filter for it, i don't have the part number as i have a mann filter on at the moment. Its a avensis mk2 2l petrol auto engine.
Have you tried eBay for complete service kit for your car, original Toyota engine oil, engine oil filter, air filter. On eBay is Snows Toyota Exeter I think. I bought my genuine oiled filer for 2010 Auris hybrid off them, very quick service.
Sounds good Catlover and probably something i will do after this service as i already bought the oil.  Rang toyota about the filter but they will not share the part number.
How much would your Toyota dealer charge you ?
17 minutes ago, Stivino said:
Try 90915-10004.
If it's not that one you can xref your Mann filter here.
Thanks for your help , but i think that part number is for the mk1 avensis i have the mk2 .
Check again. I've definitely found it for mk2.
I've just double checked, it also fits the 2L mk1.
You can see alternate part numbers and what cars it fits here.
Personally, I wouldn't bother getting a genuine Toyota filter.
Oil filters, fit many cars and many part numbers cross over
90915-10004 is correct and crosses over to. The ones in bold are the common part numbers
1560016011 — TOYOTA
1560176008 — TOYOTA
156017600871 — TOYOTA
9008091210 — TOYOTA
9091503004 — TOYOTA
9091510002 — TOYOTA
90915-10004 — TOYOTA
90915-CA001 — TOYOTA
90915TA002 — TOYOTA
90915YZZA1 — TOYOTA
90915YZZE2 — TOYOTA
90915-YZZF1 — TOYOTA
90915-YZZJ2 — TOYOTA - https://www.ebay.co.uk/itm/323956898463 message the seller with your reg
Thanks very much for the info I’ve managed to find a filter but it is part number  90915-YZZM3
Is this ok?
Most sellers on eBay are asking for reg and vin number before they send, just to make sure it’s the right one. Is your seller not asking that?
I used the same part on my Corolla. It was exactly the same as the factory original one in every detail apart from the number stamped on it. I believe the ones ending in 1000x are only available to the factories, whereas the over-the-counter equivalent will be a YZZ part. Several different part numbers exist for the same filter, it seems a bit daft.
Going to need a sump plug washer so I have decided to buy ten at a time.
on Amazon they have the 12 mm aluminium some plug gaskets.
AIEX 15PCS 12mm Oil Drain Plug Gasket, Aluminum Drain Plug Gaskets Crush Washers Drain Plug Gasket Oil Drain Plug Washers for Toyota/Lexus Scion (Blue) https://www.amazon.co.uk/dp/B09M9XMLFW/ref=cm_sw_r_cp_api_glt_i_QA0JE1CJMN7QAB4PRDEH
will these be right?
