Clunking noise from front driver wheel
chana100red
Hey Guys
out of nowhere I started getting clunking like noise from the frontdriver
any more detail ie speed specific, when going straight, corners, full lock, anything
Hi
The noise appears to be when I a driving along the road, going over bumps and seems to be constant but does go away and come back.  I feel it is a start of something failing on the car.  Had these issues before on my old Avensis and seems to be a common issue with these models.
A manufacturer defeat seems to be the obvious reason for certain Year and model of Avensis.  Obviously newer models after 2010 were better but not great!
I also read that it is VERY common on Avensis.
cheers
Dipak
  • Haha 1
Sorry - Also idling is slightly off but that is down to another issue with oil leak from the head gasket.  I replaced the head gasket a year ago and tightened up the head gasket bolts and the leak seemed to have slowed down.
Not a well balanced working car at the moment with several issues going on.
With second hand cars prices too high right now I am not considering part exchanging at the moment.
