T27 Radio Upgrade and USB Port
FTAven
Hello,
I decided to grab the Sony AX3005DB and the Fascia Kit to upgrade my current system which seems to be dying.
I’ve checked that the head unit comes with a USB port, which I wanted to route into one of the blank holes in my dashboard like shown here, but the one linked has expired and apparently does not work with Apple devices which I need to get CarPlay working.
Does anyone have any recommendations? Some I’ve seen on AliExpress require a negative and positive connection, but the head unit comes with a USB female cable I should be able to plug the USB port into.
Kind regards,
FTAven
Hi Frank. I went a different route when I got my Avensis back in 2015. I added a Bluetooth/USB adapter, since upgraded to a later unit with better bluetooth capability. At the time I got a USB extension socket, and installed it in place of the AUX only socket in the centre storage box. I did try the blank place near the parking brake control, but I didn't like the location in fear of breaking a USB memory sick or a cable it the way, while trying to operate the parking brake.
See my post:-
52 minutes ago, Konrad C said:
Hi Frank. I went a different route when I got my Avensis back in 2015. I added a Bluetooth/USB adapter, since upgraded to a later unit with better Bluetooth capability. At the time I got a USB extension socket, and installed it in place of the AUX only socket in the centre storage box. I did try the blank place near the parking brake control, but I didn't like the location in fear of breaking a USB memory sick or a cable it the way, while trying to operate the parking brake.
See my post:-
Hi Konrad. Your tutorial is the one I was linking to in my OP, it's very good and what gave me the idea to link my head unit USB female cable into a USB port to have a cleaner setup. I currently use a bluetooth Adapter plugged into my 12v port, but to use Apple CarPlay I need to plug into my head unit. The port you had linked in your tutorial is no longer available, are you aware of any currently being sold on eBay I could pick up quickly as my other parts arrive by the end of the week and AliExpress takes months sometimes.
What you want is a usb/aux, adapter/extension connects2 list them
CTTOYOTAUSB.2
the other alternative is to get a factory USB port (https://www.ebay.co.uk/itm/284598383573) - an adapter lead (USB-TY1) and Toyota cable OR a cheaper option would be to chop the end off a usb cable and wire it you self
10 hours ago, FTAven said:
Hello,
It's a USB port - as long as it's USB it will work, abite charge slowly
Did you get the steering wheel controls adapter or iso adapter ?
CTTOYOTAUSB.2
Before you posted I ended up ordering this, would it also work? I am not fussed about the AUX working, I need the USB port to work.
As for the steering wheel controls someone recommended this.
Iso adapter just gives you power and Speakers, A steering wheel adapter - Retains your steering wheel controls, but it depends on if you have the 20 or 28 pin connector to what adapter you require - Early T270 could have either
32 minutes ago, flash22 said:
Iso adapter just gives you power and speakers, A steering wheel adapter - Retains your steering wheel controls, but it depends on if you have the 20 or 28 pin connector to what adapter you require - Early T270 could have either
Could you link the ISO Adapter Kit?
1 hour ago, flash22 said:
CT20TY01
Steering wheel controls adapter are £25-35
The kit for the steering wheel control I linked above with the fascia for £89, is that decent or can I get it cheaper separately?
I upgraded my non-navi radio to oem Touch&Go. I also upgraded Speakers to Alpines and finally added Match PP 41DSP amplifier (this was plug and play). This way I got way better sound from Speakers and USB/AUX plugs to original place under armrest. Here is something about radio and speaker upgrade:
23 hours ago, flash22 said:
CT20TY01
I’ve got a 20 pin, do I need the iso?
Sorry my mistake i misread your post - you have purchased the radio and fitting kit (inc fascia)
no, you don't need anything else if you have that kit from your first post
You may need a DAB Aerial (SMB) type
on glass
https://www.ebay.co.uk/itm/402606324714
maybe a reverse camera (nice to have)
