Corolla 2004 engine problem / engine swap
Hi everyone!
Sorry if I am asking this in the wrong segment, but I can't find a solution to my problem.
Unfortunately engine on my 2004 Corolla E12 broke, long story short the oil wasn't running properly. My mechanic sad it can't be fixed/ there is no point in fixing it, I need a new engine. However, there isn't engine that I need for sale anywhere. I have a 4ZZ-FE, 71kw 1.4l vvti. E4Z-E32 to be precise.
Although, I found a 4ZZ-FE with same spec, but it is a E4Z-E52l. Does anyone know the diference between the two? And can the E52l fit my car?
If not can any other Toyota engine fit? I've read online that 1ZZ could be a match with some minor tweaking.
Any info helps.
Thank you very much and kind regards!
