No automatic lights are working re. Cargo light ,dome , drl. Dash on bright in daytime
cheri968
Recently had work done at dealer for engine light, 4WD light, traction light all on. Found small evac leak issue, but it passed test. Said ecu update, and clearing code would fix all lights being on. And it did. My car was parked outside when I picked it up. When I started it the dash lights were on Bright, in daytime, no headlights on. I am embarrassed, but I couldn’t remember if they were supposed to be like that or not!!!! So when I got home, I went to my neighbors and I had her start her car and check her dash lights. Not on in daytime,called my sister and drove her car, dash lights not on in daytime. So then I noticed my drl lights did not come when I started the car. Neither does my dome light, door light, or cargo light when I open the doors. It’s like everything that is on a delay or a sensor, does not work. I did find a fuse in the wrong place under the Passenger fuse box. When I put it in the right place, I got all my headlights back. But the problems continue with the other lights. Any idea of what is wrong. I have not checked all the fuses under steering wheel. I am a woman, not a mechanic, and not electrical. Please keep your answers simple. Lol
By the sound of it, the problems started after work was done in the dealership. So think you need to get back to the dealer, say the car hasn't been right since they had it, explain what isn't working, and arrange for them to have a further look.
At the end of the day, there shouldn't be a misplaced fuse in the fusebox, etc.
