Hi, i have a Corola 2004 Automatic shift, 4 cylinders, 1.8Lts.
I have oil in radiator, but oil in motor is OK. What could be the problem?
Thanks for your help
Head gasket failure?
Head gasket failed.
14 minutes ago, TonyHSD said:
Head gasket failed.
Certainly a head gasket failure, get it replaced ASAP.
Pink or brown sludge ? If it's a proper auto, the radiator may have failed (Its a split rad with trans cooler)
Is it a UK, Jap or USA built car ? What letters does the vin start with ?
Either way, don't drive the car until it's fixed
