CV joint for Yaris Verso 1.3 2003
amazighman
Just figured it all out, some companies list internal spines and other list internal teeth - a 22 spline has 23 teeth what is a type A, Type B is 21 Spline and 22 internal Teeth add in it also fits the Yaris what can be French or Jap built (yaris verso is Jap built)
43470-59455
https://vehicleaftermarket.skf.com/uk/en/products/VKJA3782 what's the same as the T sport
I just went and tried the cv joint i got today , it just spins around , meaning its too big for the shaft.
I again counted teeth on my old CV.... Its 22
I think the above is the right one , looks same an has 22 inner teeth and exactly the part number Flash provided , it also measures the same as my old one.
The one i received had 23 teeth , although seller stated it fits my car and has 22 inner teeth
I can't understand how there can be a difference between splines and teeth? If I look at a clock face, It's got twelve numbers on it and twelve gaps between those numbers.
3 minutes ago, flash22 said:
A clock has 12 numbers and 11 spaces in between
's funny, all mine have twelve of each..................................
Don't mind be I'm just loosing my marbles - i have got to stop multitasking
  • Haha 1
