Belt noise
Michael mc c
On 2/24/2022 at 1:39 AM, Michael mc c said:
Hello I have a 2013 Toyota avensis t27 saloon 2.0 d4d  can anyone tell me if they have had a belt noise like it's slipping under load I replaced the belt with a new one and it still makes the same noise I even tried using belt spray if anything it made it worse. would it be a tensioner that's needed or a pulley elsewhere when going up hill or when changing to second third ect just seems like the belt is slipping and making a sqealing noise I took it to a mechanic who replaced the fan belt but said he didn't see anything wrong with the pulleys and was told its pointing towards a tensioner but it is annoying anyone else had or have this issue ??? 🙁
A known issue on 2.0 subject to a technical service bulletin
EG-0014T-0114
Subject: 1AD-FTV V-Belt abnormal noise
Models: AURIS; AVENSIS; COROLLA; VERSO
Model codes: ADE150; ADE157; ADE186; ADT250; ADT251; ADT270; ADT271; ADE150; AUR20; AUR21
DESCRIPTION OF PHENOMENON Some customers may experience and report squeaking noise from BELT, V-RIBBED around 1500~2000rpm, due to slipping of the belt on the pulleys.
PRODUCTION CHANGE The design of the BELT, V-RIBBED has been changed to avoid slipping.
Thanks for that Devon Aygo hopefully my Toyota dealers will have the correct belt for me to fit and cure this annoying squeaking noise
update just received my belt from Toyota dealers as you said Devon Aygo I got the belt
90916-02736 belt v ribbed hope this cures the squeaking noise
did you get the belt that by passes the air con by chance boss. plus when i put in your belt number the one with that name comes up says its gates belt whats stamped on it dose it say toyota
I did ask for a shorter one They said they only sell the one type of belt for my model of car it says Toyota lexus on it and then 90916_02736
Well folks took the car to the mechanic this morning and he said all the pulleys including tensioner is all perfect AC unit perfect too and all that squealing noise I was having is now gone cure was the genuine Toyota belt I got I'm well pleased took it up steep hills in hi gears also to make sure it was ok under pressure it's like a new car lol it's a good dry day so dunno if that helps I will know better on a wetter day maybe but the last belt I put on two weeks ago made the noise right away so I think it's cured thanks everyone for your help 😊👌
  • Like 3
glad i told you that as  a taxi man told me that he had that anoying squealing and well 2 mechanics said all was working was ok and no fault .it was then leaving it into a toyota mechanic the taxi man told me a genuine toyota belt fixed the problem. im glad it fixed your problem also . says alot about  genuine parts .on my car i am only going to genuine toyota parts into it no mo motor factor parts for me i got enough of a sickened of motor factor shops off brand parts .the worst i had on my last car was off brand break discs and pads always after a month started to pulsate the breks shaking the car that happened me twice and well twice was me buying motorfactor parts . pure junk . plus micheak suppose u save money in not leaving it into toyota to find out that was the problem. i bet the last belt took out looked like new to. by chance what was the make of that belt that was in your car that was squeaking. was it gates or blueprint . plus michael well toyota would say going by your car and vin number it would have a ac pump in it and well on there record will say the belt u needed was one with a ac pump on it . kina need to find a toyota with a 2.0 d4d engine code  1adftv engine without a ac pump and maybe get a ac belt for that car a toyota one and hope it fits ok bypassing the ac pump. i to be honest not sure how long these ac pumps last before they start to give bother but might be a good idea to look into . i hope someone on here knows what ac bent number is and a link to getting it to suit the 1adftv 2.0 engine without a ac pump as i know this can be done.
2009joe definitely it helped me out takes alot of stress off was driving me nuts not knowing what it was I can't believe by just changing the belt to a genuine Toyota one would make all the difference the last belt was only two weeks old not sure what the brand name was on the old belt but the minute it was put into the car it was squealing
Aye a taxi man I know told me that that off brand non genuine one was a few mill thicker and that was making the noise up agains the pulleys etc as the genuine Toyota one is made perfectly.be interesting 2 know what make the belt is as would be great for others to stay away from that brand .by chance is there any markings on the belt to let us know. Plus bud no matter how old the car is put genuine parts in well belt for sure and break disc and pads .filters etc I think as long as the oil is good quality and for the car should be good I see Ur not far from me if u need me run my scan tool if ever have a problem il run it on it for free .I bought a autel 808 pro there bought it as it has few extra features than my other one .I'm going 2 sell my other one on
I still have the old belt dunno why I won't be using it ever again I will look tomorrow and see if it has a name on it to let people stay away but will be gettin my service stuff and that from dealers from now on worth paying that little bit extra for genuine quality
Yep saves alot of headache plus bud it's a Toyota 2.o should not give many problems drive it into the ground that's what I'm going 2 do with mine .drive right Into the ground .there a real comfortable crusing car
The other belt I bought just 3 weeks ago and didn't cure my problem I just checked there was a Dayco 736k7 7pk1870
The other belt I bought just 3 weeks ago and didn't cure my problem I just checked there was a DAYCO 736k7 7pk1870
Class off brand motor factor junk.at least everyone knows tbh I was wondering was it a good brand like gates etc that would cause that .another quick question u got your genuine Toyota belt from Toyota I'm wondering dose Toyota make there own belts by chance was there any other brand names printed on the Toyota belt also bud
This is those junk belts to stay away from
Belt For 1 or 2 AD Avensis without AC 90916-W2034
Buddy is that a genuine Toyota one can u send me the link to one going 2 buy one because as soon as this one is no good I'm bypassing my ac compressor and taking it off plus other ac things as I have no use for them .plus by chance this fit my 2014 2.0 d4dv 1adftv engine please
The Only names printed on the belt 2009 joe was Toyota,lexus just
I can't seem to find a genuine Toyota one for sale online .when I put in that number gates comes up and we'll don't want to risk it rather If can get a Toyota belt shorter one
2009joe I got mine from the Toyota dealer near me only ten mins away from me took 5 days to come. it was Donnelly and taggart in Eglinton I got my belt from if u type into Google their name you should get contact details I ordered mine over the phone payed for it and got a message to collect when it arrived they said they only do one type of belt for avensis it worked for me my car is quiet no sqealing at all and feels great in every gear. they may even post to an address I didn't ask cos their only ten mins away from me so was happy to collect you could ask if they can post to you
Aye been to that before that place .I see they sell second hand cars there I went to look at one they told me was a trade in a Toyota avensis with 60k and it stank of dogs and was tore up the door cards with dogs nails plus good few scratches on the read door beside lock on body of the car they wanted 7gs for it .I said na he told me u came and looked at it he said must thought was a good deal I said yes it was but not that one as was stinking of dogs were in it and all tore up. So didbt bother with it got a great one from English car auction BCA. Was way better spec  2  business EDT one the one in taggerts was cloth seats and was rough .glad never got it told the guy most would go was 6200 he was not budging .I didn't care tbh
I have the active model very basic i did test drive a 2014 one business edition same colour and all as what I have now great spec but the body work was a bit rough and it didn't drive as smooth as this one plus had alot of miles I went for the cleaner one with full service history and well looked after old guy owned it only two owners from new
The one I have had full service Toyota history with genuine 36k on the clock when I got it no damage at all only the stupid silver driver's door inside trim as the person had it must have had a ring scratching up against it .even the diamond cut rims had no damage at all .I got my 2014 back over a year ago year and a half for 8gs
The belt fits both 1AD and 2AD engine without AC
Toyota UK never offered a 2009 > Avensis without AC so no one is going to stock it but your Toyota dealer can order it
Thanks ever so much must ring the garage up get them to order me in one do I just need to give them the belt part number and will it fit the Toyota t27 2.o d4d 1adftv as you say bud
Without ac 90916-W2034
