Just seen this advert
TOYOTA COROLLA MK12 E210 2021 1.8 HYBRID CLUTCH KIT
  • Haha 2
I’d be interested in what comes in the kit 😀
You know what, it took me a bit of time to twig this.
It’s Sunday morning and I a bit slow!
There's something akin to a clutch in the hybrid system, it's a damper plate. If you have watched any of the Weber university videos about the Prius hybrid teardowns, you'll see it mentioned. I imagine that is what the advert is referring to.
  • Like 4
Sounds a bit like a main dealer quoting me for a sevice on my diesel CRV including new spark plugs.
When of course it should have been for a new diesel infrumper and plasamastic receiver.🚐
  • Haha 1
Don't forget the Turbo-Encabulator and Piston Return Springs!
  • Haha 2
Hahah,
all Toyota hybrids has a clutch damper ( similar to manual transmission clutch that is hard connected, no slip, no engaging and disengaging). Springs can wear off and break, cause a slip and hybrid system malfunction warning. When I had the warning myself I did check mine and was fine. On previous gen 3 these had some cases that springs give up due to an excessive engine knocking because of blockage in egr system. Here interesting video.
  • Like 3
  • Thanks 3
Thanks for making me feel sane again!
  • Haha 1
