Fuel consumption display and monitoring
Hi all,
Can someone help me with this- how do find info on 1) distance and fuel efficiency for trips and 2) same since last fueling?
In my past car:
#1 was shown as current drive information and I think it combined for 2 hours of data (if I did multiple trips in 2 hrs) unless I reset.
For #2-  I used for brim to brim fuel consumption calculation. When I filled the fuel, I would reset and then it will log the distance and fuel consumption until next fueling.
Manual says there data for distance and consumption 1) since start 2) since reset and 3) since refuel. Can somebody illuminate me please?
Thanks,
Sol
On mine I go to the menu button, and then select the Info tab. This rings up a display with the batteries and shows the charging. At the bottom of the screen are two options - Energy and History. Click on History and you should have the info you need.
Thank you, i would check. The car has a bit different infotainment system but equivalent option should be there.
14 hours ago, Spo2 said:
Hi all,
In my past car:
Thanks,
Sol
If you use the MyT app it will show mpg for each trip , under Hybrid Coaching , All Trips 👍
I've never used this on MyT. I check my car and log my mileage and fuel to work out my consumption manually.
@Big_D: There is a free app called Fuelio which does this brilliantly. Btw, is there a way to check tyre pressure from the cabin?
It's a nice feature of My T, handy to see what difference temp, A/C on or off, heating on or off, makes on a given trip. My T gives optimistic results for fuel consumption, but they are not so wild, and it does give you a good idea for every* start/movement/stop sequence of the hybrid system.
* it occasionally misses a trip.
I’ll have a look at Fuelio.
as far as I know there is no way to check tyre pressure from inside the cabin. The car will alert you when your tyre pressure is low.
