It looks like some cheap chinese android headunit.
What! On a 2022 Corolla.
Scott, what is the problem/query?
Its some Chinese piece of junk a member had the double din version, ripped it out and replaced with a pioneer unit*
622475381_CarRadio27022022.jpg.163f97537
it could be in a corolla but a Chinese (Toyota GAC or FAW) built one
Edit. Found it on AliExpress (QT10 Justnavi) for $110 -150 - as i said its Chinese tat
No problem just think it looks a better option with out the bevel around the edge this is a group for discussion I think u look to quickly for a problem 😉
That is not the unit I posted mate nothing like it I took the pic from a review on line so assumed it was factory fitted
It's seems to be factory fitted but a bit shit this is on YouTube
To be honest, I didnt understand what it was. To me it looked like what would be the standard fit in a 2020 Corolla. I coulnt see any indication it wasnt your car and it was an add on.
Its NOT a factory system - its chinese tat, it's the similar product just in a different format (it's just a glorified Android tablet)
I posted what it was above,
Just found it for £81 quid, so you know their cost to build is less than half that
https://www.aliexpress.com/item/1005002941239067.html
As you can see they sell the same tablet base for loads of models, note the reset and mic holes in the top left
https://www.aliexpress.com/store/5974251
Oem radios are made by Denso Ten or Panasonic (Matsush-ita) some models have Pioneer built units (Aygo)
